C1336 zero calibration reset
Hello all,
I did a search for this but I didn’t see anything. I’m a new member. I just came into a 2002 Camry SE V6. It has 190,000 miles on it. I’m planning on giving it to my 16 yr old for his daily driver after I fix a few things. Anyway, a bit of history. The vsc/trac light is on with no engine light. I originally had a boat load of codes on the ABS side. Basically all the ABS system. Wheels sensors, master cylinder, abs pump, etc. I started at the top and checked all the abs fuses. They were fine. The abs relays tested fine. All the test runs on my scanner came up good. After that, i took off both battery leads to reset (and they were a bit corroded and cleaned them). The only code now is the C1336 zero point calibration of deceleration sensor undone. After looking this up, it appears I need to reset that zero calibration. I saw some videos and info online about it. But all for diff model Toyotas. And I’m actually having a tough time finding the cg and ts slots on my OBD. My scanner doesn’t have that capability. anyone happen to have that procedure or those slot #. So I can reset that calibration ? Thanks |
"cg"?
The reset procedure should be the same for 2002-2007 Camry and assume other models around these years. See private message. |
