camry 97 replacing front speakers
can some send me a link or instructions on how to install front door speakers on Camry 97 v6 model. Thx in advance.
Might try the AutoZone websites vehicle repair section for info.
The door panel needs to be removed. The speaker is held in by three screws from the front. Check the site for info on replacing the power window motor which also requires taken off the door panel. |
Hey mate,
To remove door panels... - Remove the window winder (if you don't have electric windows) - Normally use a sheet of some sort, slide it under the lever and pull towards the centre of the lever itself... it'll hopefully unclip the "horseshoe" looking clip that holds the window winder thingy onto the door panel :) There's some info, not 100% related to your question, but gives you a few pics and where the screws are that need removing to get the panel off. http://www.toyotanation.com/forum/sh...d.php?t=264887 See how you go with that mate.. |
