Camry Engines 1984-2014 engine repair PDFs as at Jan 2016
13 Attachment(s)
starting research from wiki camry lists https://en.wikipedia.org/wiki/Toyota_Camry then build on that
found this site good for engine designation for any year camry Select Your Model Engines ALL For Four Cyl and V6 covering 1984- 2015 Camry engine repair manuals in pfd can be found FREE on the internet additions from members in this topic or new data welcome V10 (1982–1986) 1.8 L I4 gasoline (1S-L,-LU) 1.8 L I4 gasoline (1S-iLU) 2.0 L I4 gasoline (2S-EL,-ELC,-ELU) 2.0 L I4 gasoline (3S-GELU) 1.8 L I4 diesel turbo (1C-TL,-TLC) 2.0 L I4 diesel turbo (2C-TL,-TLC) V20 (1986–1990) 1.8 L I4 gasoline (1S-i) 1.8 L I4 gasoline (4S-Fi) 2.0 L I4 gasoline (3S-FC) 2.0 L I4 gasoline (3S-FE) 2.0 L I4 gasoline (3S-GE) 2.0 L V6 gasoline (1VZ-FE) 2.5 L V6 gasoline (2VZ-FE) 2.0 L I4 diesel turbo (2C-T) Wide Body Camry XV10 (1991–1996) 5S-FE / V6 3VZ-FE /V6 1MZ-FE XV20 (1996–2001)5S-FE 2.2 L I4/V6 1MZ-FE XV30 (2001–2006) 2AZ-FE I4 1 1MZ-FE 3MZ-FE V6 XV40 (2006–2011) 2AZ-FE I4 2GR-FE V6 XV50 (2011–present.) 2ARFE L 4 2GRFE V 6 Hybrid ( 2AZ-FXE four-cylinder)... Toyota Hybrid presentation 214 pages https://autoteacher.net/uploads/Toyo...esentation.pdf Diesel.. see Post 2 the engine repair PDFs found free online so far Cant find any Camry 1, 2 or 4 S engine pdfs see attachment for a picture of a 1 S 3S-GE 495 pages Pdf wiki says this type was fitted into V10 (1982–1986) http://www.mr2australia.com/st202_rm396e.pdf (4A–FE) (3S–GTE) (5S–FE) 311 pages pdf (random find ) http://www.manualesdemecanica.com/im...8c81d4f67f.pdf V10 (1982–1986) ...V20 (1986–1990) 3S-FE and 2VZ-FE 175 pages ..... engine mechanical section http://www.playnice.org/pdf/Toyota%2...Mechanical.pdf Wide Body Camry 5S-FE 431 pages http://www.turboninjas.com/camry/eg1.pdf ENGINE MECHANICAL to page 144 EMISSION CONTROL SYSTEMS MFI/SFI SYSTEM page 164 COOLING SYSTEM page 238 LUBRICATION SYSTEM page 268 DIAGNOSIS SYSTEM page 296 CIRCUIT INSPECTION page 336 1MZFE 599 pages pdf .... section http://www.turboninjas.com/camry/eg2.pdf ENGINE MECHANICAL to page 195 SFI SYSTEM page 217 COOLING SYSTEM page 313 LUBRICATION SYSTEM page 367 DIAGNOSIS SYSTEM page 399 2AZ-FE 85 pages pdf http://www.shinny.co.uk/toyota/3MZ-F...Mechanical.pdf 2AZ-FE & 2AZ-FXE Throttle Body http://alflash.com.ua/avtovideo/2/2a...lebody_tsb.pdf 3MZ-FE engine mechanical 143 pages pdf in total.see attachments . broken down to forums upload limits 3MZ-FE . 15 pages - PARTIAL ENGINE ASSY COMPONENTS (3MZ-FE) http://highlanderclub.ru/files/manua...p/conponen.pdf 3MZ-FE 7 pages ..Timing belt http://highlanderclub.ru/files/manua...1p/x040001.pdf 2GR-FE V6 used XV40 (2006–2011) bonus find apart from the engine section a 1021 page pdf ... on this 2GR-FE engine and systems http://mr2.bordeauxgroup.com/AVTO0566.pdf ENGINE MECHANICAL – ENGINE UNIT ...up to page 156 ENGINE CONTROL SYSTEM – SFI SYSTEM page 157-638 ENGINE CONTROL SYSTEM – MASS AIR FLOW METER page 639 CAMSHAFT TIMING OIL CONTROL VALVE ASSEMBLY page 643 VVT SENSOR page 652 CRANKSHAFT POSITION SENSOR page 659 ENGINE COOLANT TEMPERATURE SENSOR page 665 THROTTLE BODY page 669 KNOCK SENSOR page 674 IG2 RELAY page 681 AIR FUEL RATIO SENSOR RELAY page 684 Electronic ACCELERATOR PEDAL page 688 FUEL PUMP page 738 the rest is all electronic information ending with or without the smart key small pdfs are exploded views engine assembly 13 page pdf http://marclabranche.com/V6MR2/2GRFE...ine%20assy.pdf engine assembly 11 page pdf (back up site ) http://share.qclt.com/%E4%B8%B0%E7%9...e/00800310.pdf head gasket 6 page pdf http://marclabranche.com/V6MR2/2GRFE...d%20gasket.pdf |
1 Attachment(s)
Toyota Camry Turbo Diesel ....short production run ..... special edition
anyone see one for sale in america please post it up from wiki V10 (1982–1986) 1.8 L I4 diesel turbo (1C-TL,-TLC) 2.0 L I4 diesel turbo (2C-TL,-TLC) V20 (1986–1990) 2.0 L I4 diesel turbo (2C-T) in August 1988 a diesel version of the Vista hardtop made its debut, and the 1.8-liter gasoline engine was upgraded to the twin-cam 4S-Fi specification.[67][68] Special editions for the Camry comprised: Lumière S sedan (January 1989), Prominent X hardtop (May 1989), Lumière G sedan (June 1989), and XT Saloon Special sedan (January 1990). source http://www.carfolio.com/ Toyota Camry Diesel manual gearbox Toyota Camry 1800 Turbo Diesel XT specifications, information, data, photos 24508 Toyota Camry Diesel automatic gearbox 1986 Toyota Camry XT Saloon 2000 Turbo Diesel Automatic specifications, information, data, photos 312576 the diesel download sites I found for 1C and 2C were ZIP types and not safe to continue closest I could find 172 pages .pdf 2L-T 3L http://www.toyota4wd.dk/Teknik/J70/T...nual%202Lt.pdf trying to find a running toyota camry turbo diesel only example I could find of a running diesel Toyota Diesel in a vista sedan running 27 seconds |
I would be interesting to learn more about non US Camry cars which can be more interesting.
Non US camry s
Intersting question they are just as hard to work on and have the same toyota problems Cosmetic changes only on all models The steering wheel pedals and instrument dash and console is swapped to the other side drivers seat is passengers seat |
grrrr some one asked an specific engine question
took me several pages of DIY ..to go find this write up bookmarked on my puter |
