Camry Gearboxes and Engines 1984-2014 workshop PDFs as at sept 2015
1 Attachment(s)
UPdated Jan 2016 some links closed some others new
all engines in this new link https://www.camryforums.com/forum/di...-2014-a-50782/ Reading for later @ toyota wiki http://en.wikipedia.org/wiki/Toyota_...2.80.931986.29 Gearboxes ALL For Four Cyl and V6 versions manual and auto most of these gearboxes repair manuals in pfd can be found on the internet just takes searching --covering 1983- 2014 hopefully Write ups on removals and any corrections in this topic or new data welcome Quote "toyomoho : Look on side of drivers door for sticker listing various items including trans model." information in this topic will be from various sources ... if you dont have the set up and special tools - gearboxes are best removed with the motor through the top Toyota All gearboxes wiki -------In time all the correct camry ones will be identified http://en.wikipedia.org/wiki/List_of..._transmissions Contribution From toyomoho on Manual gearboxes Quote 2002-06: 2AZFE was only engine option offered with stick which was model E351. 1992-2001: 5SFE model S51. 1994-2002: 1MZ-FE E351. 1992-1993: 3VZ-FE E53 (source Wikipedia). 1988-1991: 3SFE S51, 2VZFE E52. 1988-1990: 3SFE used E56F5 on 4-wheel drive Camry (All-Trac). With minor exceptions info is from Camry factory shop manuals. Wikipedia has variations on this such as not listing E52 or E56F5. Info is for US cars and does not Camry Solara. "end quote " Manual Gearbox Listing 1984 - 1994 Camry S51- E52 and E56-F5 Clutch section 13 pages see attachment S51-S53 .... 29 pages http://bgbonline.celicatech.com/6g/t...0s53%20s54.pdf 1988-1990: 3SFE used E56F5 on 4-wheel drive Camry (All-Trac). 1988-1991: 3SFE S51, 2VZFE E52 1992-1993: 3VZ-FE E53 (source Wikipedia). 1997-2001 Camry 1MZ-FE E153 [I]2002-06: 2AZFE was only engine option offered with stick which was model E351. E52 4 pages april 2015 PDF link down or closed have found a parts link Manual Transmissions by Unit Code: E51, E52, E56, E57: Manual Transmission Parts - Online E56F5 missing link E35[/B]1 -97 pages 2006–2009 Toyota Camry (XV40) EB62 (no free pdfs --you can get basic car repair manuals ) 2009–present Toyota Camry (XV40) Wiki on The A series automatic trannys Camry Toyota A transmission - Wikipedia, the free encyclopedia A140E and A541E 115 pages http://www.turboninjas.com/camry/ax1.pdf 1983-2001 Camry A540H-A540E. 200 pages http://shop.ukrtrans.biz/wp-content/...logs/A540H.pdf A140L 102 pages http://www.all-trans.by/assets/site/...oyota/A140.pdf 2 pages parts layout only http://www.automaticchoice.com/uploa...ue/aw_a140.pdf 1985-1986 Camry TurboDiesel------( I didnt even know they made a turbo Diesel Camry ) 4 Speed Hydraulic Controlled Automatic Transaxle (2-way overdrive) Applications: Wiki on all U series automatic trannys ....Camry.... Toyota U transmission - Wikipedia, the free encyclopedia - In time all the correct camry ones will be identified U140E and U214E 118 pqges http://www.turboninjas.com/camry/ax1.pdf a zip kit info 8 pages http://www.abtomat.ru/img/cat/U140E-U241E-ZIP.pdf U151E 2005–2006 Camry (V6) 24 pages http://share.qclt.com/%E4%B8%B0%E7%9...nit/027013.pdf U241E - 20 pages 2001-2009 http://share.qclt.com/%E4%B8%B0%E7%9...nit/029013.pdf 20 pages pdf http://share.qclt.com/%E4%B8%B0%E7%9...nit/029013.pdf slow to download 168 pages pdf http://shop.ukrtrans.biz/wp-content/...logs/U241E.pdf U250E 8 pages http://www.atraonline.com/gears/2009.../2009_1_18.pdf U660E 8 pages http://www.transtec.com/downloads/te...ota/B94734.pdf 4 pages pdf http://natpronet.com/trans/U660.pdf U760E FWD 6 speed 2010– Camry (I4) parts list http://natpronet.com/trans/U660.pdf P311 2007 Camry Hybrid - CVT gearboxes require special oil ..clear to look at or green - not red - and labelled suitable for CVT transmissions only add the wrong oil and goodbye gearbox when to change a CVT gearbox oil found some information on CVT transmissions CVT transmission oil change question if the service book says nothing about a CVT oil change interval kms or mileage is not used as a oil change interval guide not a monthly or yearly time frame the life left in the CVT transmissions oil is calculated by an oil test and scale % of deterioration ask how much it is for a CVT fluid analysis ? to get its oils deterioration date CVT type toyota boxes explained 30 minutes CTV trannys of all Camry/Prius /design of first second and third gen |
Stickied this. Nice info, dirty hands.
Cool I'll take a look
update early 2015
i havent found anymore information online to update this topic |
Have you ever found any info about why some auto trans of the same model have raised letters on the case and others have stamped letters?
The used trans dealers list raised and stamped lettered trans of the same model separately for reason unknown. |
I have been searching ever since that question was posted last year
its the same gearbox external and internal --as far i can see-- both bolt on never see this before myself I cant even get a picture of the two different cases to investigate I can only speculate a design change during the run of the box - different alloys or case shell thickness modification ..that had to be casing specific would have to chase down the suppliers of the gearbox- assembly plant records etc Needs two different moulds and techniques on the same casing and gearbox design raised lettering or stamped could be done anytime during the outer case forming |
Perhaps a casting improvement change that included cast letters to eliminate stamping of ID. Or two different manufacturers, etc
It appears even used trans sellers don't what the difference is. The issue is seekers of used trans don't know if one can be substituted for another. |
1 Attachment(s)
Camry Transmission .in a 2003 camry .is the box the forum topic was about
https://www.camryforums.com/forum/di...ication-49847/ this particular box was used for years 2001 to 2009 in toyotas..thats a lot of years for any changes I would say any U241E raised or stamped will have the same box internals and housing should bolt on first time ever the raised letters have been raised in any forum I found a repair manual for it today and added it to the list of auto boxes - 20 pages also found this information online --mentions stamped boxes only a few times 9 pages pdf 2006 – 2009 ... http://www.toyotapart.com/AUTOMATIC_...SB-0200-08.pdf |
additions to research on camrys
Camry engines 1984-2014 workshop PDFs as at January 2016 forum link https://www.camryforums.com/forum/di...-2014-a-50782/ |
