Camry Ignition troubleshoot guide
Looking for a troubleshooting guide for Ignition problems. I have followed the trouble shooting guide in the Hayes manual and have not found the issue.
No Spark - Distributor is clean and dry - Power to the distributor is 12v - Internal coil resistance checks passed (replaced anyway) - Power to the Ignition Control Mod is 12v - AutoZone performed test on ICM and passed - Fuses all look good and hear a click at the ignition relay Need help to continue this troubleshoot process. |
Year of car and engine model?
The year is '92 and the engine is the 4 cyl 16 valve. I found the problem and have spent the rest of the day replacing the broken timing belt.
At the same time I have also replaced the water pump which is right in the same procedure as the timing belt. I have followed all the procedure as I understood and I must have missed one of the finer details of the spark timing. I have spark now but still have not got a start. Given the belt broke I returned the crank and cam in their proper TDC positions and following the procedure hand cranked 1 full cycle to check all the alignments. All looked good. My suspicion is that I have the distributer 180 deg out. |
What proceedure did you use to get the cam and crank pulley at TDC?
