Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   DIY - Do It Yourself (https://www.camryforums.com/forum/diy-do-yourself-22/)
-   -   Check Engine Light Code PO770 Lock-Up Solenoid Help (https://www.camryforums.com/forum/diy-do-yourself-22/check-engine-light-code-po770-lock-up-solenoid-help-39188/)
1985sr5 08-04-2011 06:37 PM
i have 1997 toyota camry with a p0770 code (lock-up solenoid) i have replaced the solenoid and the computer i have tested the wire (pink) from the computer to the solenoid and its good i have tested the solenoid as well ran 71 psi of air to it and powered it on and it works fine. the only other thing i can think of is the valve body is pluged or the torque converter is bad Trans is a A140E Any Ideas
toyomoho 08-04-2011 08:19 PM
The code means lockup does not occur within a given range or lockup occurs but the trans slips.
Could be the lockup clutch on the converter, stuck/blocked valve in the shifter body or slipping brake or broken gear in the trans.
full house 08-04-2011 08:53 PM
I'm not too familiar with those codes, every time I can't find solution I ask experts.
1985sr5 08-04-2011 10:30 PM
well should i do a rebuild on the trans and new converter. the trans has 346500 miles on it the only thing ever done is the fluid and filters. and the trans oil pump at 140000 miles. never been in the trans yet. but it still shift fine. does not slip. but i guess its alot of miles on a trans.
toyomoho 08-05-2011 10:26 AM
The valve body can be removed without taking the trans out of the car. There is a hydraulic relay valve inside that slides to transfer pressure to the converter clutch.
The torque converter can be removed without taking the trans itself apart.
1985sr5 08-05-2011 08:23 PM
will a 1996 toyota camry trans work with a 1997 camry i can get a jasper remand for $75 that still has 10months on the warranty it was rebuild in 2009
toyomoho 08-05-2011 11:17 PM
The info found states no. The listings run 92-96 then 97-01.
What the difference is don't know.
Might check at the Toyotanation website where members have swapped a lot of trans for this model car.
1985sr5 08-11-2011 02:09 AM
just wanted to let you all no that a 1996 trans worked just fine. every thing is the same all the plugs cv shaft spine, trans mount. trans works grate. passed emissions test... thanks all
toyomoho 08-11-2011 10:32 AM
Great!
The trans vendors may have posted trans models based on generation of car 3 to 4. The break between generations was 96-97.
