Disable Ignition Key Buzzer
How do you disable the key reminder buzzer in a 1996 Camry? Its driving me nuts :eek:
thanksss the best web to make more and more money www.wowlife.tk www.easymoneynow.tk
It appears the buzzer is built into the integration relay located up under the drivers side dash panel.
Might be able to connect the wires at the drivers side seat belt buckle switch together. This will fool the system into "thinking" the belt is connected. Red/Yellow and White/Black wires. The buckle is where the seat belt blade plugs into. |
Thanks Joey. I'll give it a shot. :)
