Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   DIY - Do It Yourself (https://www.camryforums.com/forum/diy-do-yourself-22/)
-   -   DIY Headlight Painting (https://www.camryforums.com/forum/diy-do-yourself-22/diy-headlight-painting-40791/)
ISboost300 07-06-2012 02:38 AM
11 Attachment(s)
I have done this mod on lots of other cars and it came out great on my wifes camry. Here is a quick write up on how to PAINT YOUR HEADLIGHTS.
First off remove your bumper.
Attachment 4082
Unhook all of the electrical connections to the lights and remove the lights
Attachment 4083
Heat the oven to 215 degrees F.
There will be a few screws on the back of the lights that hold the lens in place. Remove these screws.
Now place the lights in the oven for 15 min. Making sure the lights do not hit the side of the oven.
Now with gloves slowly pull the lens away from the housing. I start with a small flat head screwdriver ever so slightly to get it open just enough to pull it apart with my hands. Do this VERY VERY slow. If the lens does not separate easily put the light back into the oven for a few more min.
Attachment 4084
Now once removed take the chrome part out. There will be a few more screws here too.
Attachment 4085
Now paint your desired color. I took blue tape and taped off a chrome ring around the projector light area. I use Krylon Fusion spray paint
Attachment 4086
Making sure the paint is dry re assemble the light back together and re heat the light in the oven at 215 degrees for 15 min.
Attachment 4087
Attachment 4088
After heated and still hot press the edges of the light back together with the lens to reseal the light.
Re install the lights and bumper. Connect the electronics and enjoy your work
Attachment 4089
BEFORE
Attachment 4090
AFTER
Attachment 4091
Attachment 4092
NOTE: Please dont forget to take your lights out of the oven. I do not assume responsibility for you melting them.
