Door locks out of sync
I recently replaced a door lock actuator on a 2002 Camry and door is out of sync with the other doors, for instance when it is unlocked the other doors are locked. It was not installed in reverse and the wiring was correct, what could be the problem?? is there a way to sync the power door locks on a 2002 Camry? I cannot find anything online to help.
Thank you |
If the locks works opposite of the others. Perhaps the wiring at the actuator was reversed when the unit was assembled. Try swapping the wires.
