fixing control arm on camry 92
hey guys i think i bent the control arm so i want to fix it myself but i want to make sure its just the control arm that is bent.can any one tell me how i can find this out for sure and what to look for? any help would be great. i saw some vids on youtube on how to replace the control arm but more info would be great!:D
Remove both front tires and compare the bent side with the OK side. Look at where the control arm bolts to the chassis and determine if the attach points on the frame are bent. Use a tape measure to compare potential bent location points on one side to the other side.
For detailed info on replacing the arm suggest obtaining Haynes service manual, cost under $20. Your local library may have service info for checkout or copy. |
