Front side lighting
On my 2013 LE I find the front corner lighting and night lacking. In very dark conditions when turning I can't see where I am turning. Noticed that LES models have a light in the lower front corner a light where I just have a black plastic fake grill. Can I retrofit LES light in that area?:)
Don't know.
Examine how the fake grill is attached. If it can be detached, as in just a space filler, then the light should be able to be installed as a bolt on. If the grill is built into the part around it, then the issue becomes more difficult. Look behind the grill area for any detached wiring plug, meaning the wiring plug is place. If all wiring is place is a different story. |
Do you mean fog/driving lights? If that is the case, yes you can. I've seen a few kits around.
