Fuse box diagram?
Hey, I have a 2002 Camry. Does anyone know where I can see a more detailed fuse box diagram? Many of the abbreviations are ones I don't understand.
Or, if not, does anyone know if there is a specific fuse for the receiver to the keyless entry system. I'm trying to narrow down what is preventing my remote from working. I've already replaced the battery. I know about reprogramming the remote... but want to check the fuse before I go through that process. Any help would be great... thanks! |
Check DOOR1 fuse. Fuse box, engine compartment, drivers side.
DOME and ECU-B fuses. Fuse box behind lower finish panel of dash board. Far left side, area below left air vent. |
http://echopic.com/17iz.gif
maybe this would help. |
This is not a fuse problem. You will have to check your owners manual for a code to unlock the radio, or go to your dealer with the VIN, and they should be able to help you.
Any luck with a local salvage yard? You might try autozones web site and search around they have a bunch of electrical wiring diagrams listed there and you can download them free.
This is not a fuse problem. You will have to check your owners manual for a code to unlock the radio, or go to your dealer with the VIN, and they should be able to help you. Do not try to enter random numbers, some radios only allow so many tries before it is locked until a dealer services it.
