Good quality fuel filler neck- not too cheap
Daughters 2000 Camry needs a new fuel filler neck tube. I am confident for $90 and above I can get a great new one. But what about the $60 or $40 new units? Anyone care to share experiences? Heres what Im observing:"
https://www.rockauto.com/en/catalog/...ller+neck,6272 https://www.ebay.com/itm/Steel-Gas-Fuel-Tank-Filler-Neck-Pipe-Hose-for-98-04-Toyota-Camry-Avalon/310346789562 https://www.ebay.com/itm/Fits-Toyota...H1.Xcamry.TRS2 |
Rockauto parts have purchased (a lot!), have always been name brand, of good quality, not fakes and they fit. Thus would say its a known source.
Ebay (and amazon) new parts can be hit or miss. Used factory parts on Ebay were OK. Suggest reviewing the feed back for any seller your considering buying from. Also consider the risk and time involved in getting (and installed) what then turns out to be a bad part, plus the sellers return policy if a bad part. For a filler neck you can inspect the part and compare the fit with the old one prior to installing it. If not up to par, send it back. |
I use RA every chance I can. I will go with the lesser priced unit from Rock Auto. Thanks toyomoho.
Great!
