How to install 8 sensor parking system
Hello, I have ordered a Beneglow 8 sensor parking system, and was wondering if anyone here has a guide on how to install it? :confused: If I will have problems when drilling the fron & rear bumpers, as I saw they have foam behind them, and also, where, and how to route the wires!, It seems a little complicated even though I know a lot about electronics & computers :confused::confused:, it is a 2001 Toyota Camry CE, any tips?
Thanks? |
Might mark then remove the F/R bumper covers for drilling and determine what is behind the area for clearance issues.
Wires can be routed through a firewall thru fitting. There is a fuse box behind the drivers side ash tray. Use a fuse tap for power. If needed the center console can be removed starting with the glove box and moving toward the dash. |
