Camrydude28 |
08-19-2022 05:19 PM |
It's it the water pump or something else?
I was having an issue with car temp gauge rising to right under the red. I replaced thermostat temperature sensor and radiator fan switch which seems to have corrected the overheating issue however now I'm having a problem with coolant loss at the reservoir. Before changing thermostat coolant was rising when car was hot above the full line then once the car cooled it would go back to full now what's happening is whatever level I fill the coolant reservoir with when I come back from driving it stays there but by the time the car cools or sits for an hour or two the coolant is gone. There are no visible leaks whether from thermostat housing water pump radiator tubes or radiator. Car is blowing hot heat with no problem. Im very confused because before changing the thermostat I was having coolant leak but not as much or nearly as much
