key stuck in the ignition on my 95 camry
hi i can not get the ignition key out of my 95 camry unless i disconnect the battery already replaced the lock can somebody help
Try wiggling the gear shifter
Try lubricating the lock cylinder with white lithium grease Check if Toyota security anti theft light is on |
I had a similar problem, no worse, except the wrong key got stuck in. Took the whole thing out to work on it on the bench and got it out. Hope you get it out without having to do that.
