LED factory tail lights
Has anyone upgrade their tail lights on a camry 07 CE to the LEDs factory no after market? Is it the same connections?
I have not but I would imagine the wiring to be different, probably not a whole lot different. I don't know too much about LED's but isn't there usually some kind of resistor to avoid flickering? Do the aftermarket ones have plug and play capabilities? Maybe the flickering is more of a concern with headlights?
You might want to check over at Toyotanation.com to see if anyone has done it there. |
Toyota nation has nothing about it either, they go for aftermarket ones which are plug and play.
You sure 2007 offered LED taillights on any model other then hybrid?
That's right!!! I didn't have that in mind!!
After market parts sites list both light options (LED and conventional) for hybrid car. Some P/N's non-LED lights listed for hybrid are same P/N as non-hybrid cars, so might be a plug-in part.
Suggest visiting a Toyota dealer and asking if these lights were an option on non-hybrid cars. They are listed but only under hybrid at around $250 each. |
