need help!!!! 93 camry 3.0 5spd clutch replacement
i recently began replacing the clutch kit in my 93 camry. went smooth up until i attempted to put trans back in. i am unable to get the trans fitted properly. any advice would be wonderful. been down for 2 weeks. missin it like crazy.....
Can you describe what is unable to fit properly?
What parts did you replace other then the clutch? The engine is still in the car? |
well, most common is mis-aligned input shaft. did you use any kind of alignment fixture to guide clutch plate back onto the flywheel exactly where it needs to go? as if you did NOT, then forget it.
2nd common is guides mis-alignments. normally, trannies have 2 large pins, or tubes, that guide trannie into its engine housing. they have to go in perfect, or bust. |
well, let me also say this - when you bought new clutch plate, you DID try if it fits input shaft splines, RIGHT? as they aftermarket splines can be very tricky, he-he.
