No air Blowing from any vents 2011 SE
When I drove in to work this morning everything worked fine. When I went out at lunch all of a sudden no air is blowing from ANY vents at all. All the lights on the A/C control panel are working as well. Any help is greatly appreciated!
So the blower is not coming on or the vents aren't opened?
The vent control is vacuum operated, take a sec and look around under the dash for any loose vac hoses for starters. If the blower is not coming on check it's connection as well, usually behind the glove box. |
Have the following checked:
Fan Motor and A/C Compressor |
Have your aircon blower and compressor checked.
