no power
My 2006 Camry would not start so I jumped it and it ran fine but has no power. I had the battery tested and it was bod so I replaced it. Still no power. You can mash on the gas pedal and it won't reve above about 1900 rpm. I had to replace the Mass Airflow sensor a couple of weeks ago and it has run fine since. Any ideas?
I would disconnect the battery and let the car sit overnight. In the morning, connect the battery, start car and simply let it idle until it reaches operating temp.
Trying driving it then. If that doesn't help, post back and we'll go from there. |
Also check for any blown fuses.
First of all, thanks for the replies guys. I disconnected the battery which was no help. I checked fuses and found the etcs fuse blown. I also got a code reader and have code 2118. causes are 1, open in etcs power source circuit and 2, poor electrical connecction. What is the etcs?
Electronic Throttle Control System.
The fuse blow when the car was jumped, replace the fuse. The codes are due to the fuse being blown. Next time, turn the lights on when jumping the car to avoid electrical surges. The throttle may take some time to adjust as it needs to "relearn" the proper setting. |
