Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   DIY - Do It Yourself (https://www.camryforums.com/forum/diy-do-yourself-22/)
-   -   Oil Drain Plug - 98 Camry - Socket Size? (https://www.camryforums.com/forum/diy-do-yourself-22/oil-drain-plug-98-camry-socket-size-22563/)
LetterX 09-17-2010 04:33 PM
Does anyone know the size socket I need to remove the oil drain plug on a 1998 Camry 2.2L? Thanks.
LetterX 09-20-2010 10:42 PM
I figured this would be a no-brainer for someone, and it would save me from climbing under the car just to find out that socket is missing from my crappy tool collection.
Anyone? Please?
toyomoho 09-21-2010 10:32 AM
Can't remember, I have wrench set. Perhaps 17 mm. You can use a box wrench with no problem, I do.
Morton 09-24-2010 04:30 AM
hello guys...
thanks for sharing information..
LetterX 09-24-2010 04:54 AM
I got under there myself, and the drain bolt is 14mm. Changing the oil on this car was easier than any car I've ever done it on. Very easy access to the drain plug and oil filter. Literally took 10 minutes without a drop of oil on my hands.
