oil shield baffle has puncture
Old 02-12-2012, 01:52 PM
PGRNPA's Avatar
Default oil shield baffle has puncture
Hi all, looking for some tips. We bought an 03 Camry in April of 2011. First time I changed the oil I saw a puncture in the shield under the filler cap. Finally it got the better of me and am researching this. Can this baffle be replaced and how difficult is it? Thanks.
Old 02-12-2012, 10:18 PM
There may be a service bulletin on this.
EG007-02
Old 02-13-2012, 04:50 AM
PGRNPA's Avatar
Saw it, says to use caution, damage can result. Nothing about a fix.
Old 02-13-2012, 07:27 PM
Can't remember is the part is available but it often breaks.
Call a Toyota parts department which may be the only place that sells it. Ask if the part is available, if so then it can be replaced.
If a 4 cylinder engine then pieces have become lodged in the timing gears causing major engine damage.
If no part available remove the cover and find any pieces you can and make sure no other pieces are going to fall off.
Toyota does not appear to have a fix.
Old 02-15-2012, 04:37 AM
speedy car's Avatar
Consult the dealer you have bought your camry.
DIYDad
03-26-2015 11:16 PM
jimmcj
03-14-2012 01:16 AM
zachwang
04-07-2011 09:17 AM
rrr
04-07-2010 09:56 AM
gslrider
06-26-2008 02:55 PM
Quick Reply: oil shield baffle has puncture
