p0328 knock sensor problem.
Greetings.
This is my first post and need some advice regarding a knock sensor (code p0328) issue I am having. I have a 2005 2.4 4cyl camry and having a difficult time locating the knock sensor, also is there only one knock sensor for the 2.4 4cyl camry, I've read there may be two but I believe it is for the V6 model. thanks. |
Knock sensor (1) is on cylinder head under intake manifold. Difficult to access without removing the manifold.
Ohm resistance should be 120-280K at 68F. |
(Post 86147)
Ohm resistance should be 120-280K at 68F. Thanks for the info. Regarding the manifold gasket I will replace it if needed, or should I replace it regardless. |
Replacing the knock sensor is involved.
The link below provides info for same engine in RAV4 which should be close. http://share.qclt.com/%E4%B8%B0%E7%9...or/0050071.pdf Take note of notation for using new gaskets, etc. Intake manifold is one of them. The intake manifold is plastic,be sure to re-install the insulator. If your up to it. Might check sensor ohm reading remotely first at ECU harness plug. See link below: http://share.qclt.com/%E4%B8%B0%E7%9...em/0050031.pdf |
