Power Steering
1 Attachment(s)
I have a 2007 Camry SE, and a slight Power Steering leak. It is coming from the return hose on the Power Steering Reservoir right were the retaining clip is. I don't need the whole tube, just the short rubber hose, but am unable to locate a part, and or a replacement that is suitable for it. Does anyone have any ideas, or can point me in the right direction? I found the whole line on Rockauto.com for $44.79, but I think that is a little much for just wanting to take the rubber section off it. Alternate/OEM Part Number(s): 4440606171
Most likely you will not be able to find a preformed replacement hose.
There is hose designed for oil coolers/power steering applications. The hose sold based on internal hose diameter and by the foot. The hose pictured appears to be a low pressure power steering return hose. This makes difference in the type of hose used. Measure pipe OD to get the correct hose size. Shop auto parts stores. |
