power steering leakage
what is the typical leakage piont for power steering hoses/lines in or out?
i have a leak and want to stay cheap. |
96 camry collector edition 200k
The drive shaft seal at the pump.
End fittings where they connecting to a flexible hose. A high pressure hose (line out) would leak more. Seals at each end of the steering rack housing. Fluid will build up inside the boot first, then leak out. |
