Power steering return hose help
I was taking off the return line at the reservoir and the hose split. Just the rubber end, not the pressurized end the return line. Can I just replace it with some fuel line hose? If not is this a part that I have to get from the dealer?
Fuel hose will work in a pinch. Not sure for how long due to the fluid being oil and hotter.
There is commonly available transmission fluid hose which will last longer. Made to fit aftermarket hoses are available, see link below: https://www.rockauto.com/en/catalog/...turn+hose,7324 |
Thanks I will check for the transmission hose.
