program key
I need a spare key for my 04 Camry and was wondering if anyone here had programmed one themselves and how difficult it was.
Thanks |
key program only by a locksmith or toyota techstream tool ,if job is done by locksmith must have a master key available when programming the extra key , if all keys are missing job needs to be done by the dealer . how to do wireless transmitters (key fobs ) programming guide :
1. Start with the following conditions: You are in the drivers seat. a. Key is out of the ignition b. Driver door is open (all other doors closed) c. Driver door is unlocked (other doors don't matter) 2. Insert and remove the key from the ignition twice within 5 seconds. 3. Close and open the drivers door twice within 40 seconds. 4. Insert the key into the ignition and remove it. 5. Close and open the drivers door twice within 40 seconds. 6. Insert the key into the ignition. 7. Close the door 8. Turn the key in the ignition on and then off. 9. Remove the key from the ignition. 10. The power locks should automatically cycle once to indicate that you have successfully entered program mode. 11. Within 40 seconds of the entering program mode. a. press both transmitter lock and unlock buttons SIMULTANEOUSLY for a duration of from 1 to 1.5 seconds. b. within 3 seconds, press the transmitter lock button for more than 1 second and release. c. If the transmitter has been sucessfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted. d. If multiple remotes are to be programmed, repeat steps A-C. 12. Open the driver's door. |
Originally Posted by Bp8501
(Post 71504)
Thanks maybe this key is you looking for. |
I was once tried to do this but end up with the help of my dad it's very hard for me.
Hi all,.
I am Looking For Info On Programming A Key Fob For A 2003 Chevy 1500 PU. I Have Info On Doing This If The Doors Have Electric Push Buttons But Not For The Slide Type Locks Which I Have?? ----------- locksmith boston |
Hi,
Any help with progaming a 2014 camry key? Thanks |
Try the link below:
Later Toyota may be dealer or locksmith only for ign key part. Still may be able to program key FOB. |
can i just get a door key made without all the programming, 2012 no smart key, just the transmitter on it.
Yes, if only opening door, trunk, etc. The programming is for ign key to start engine.
Cool, now I can go fishing. Thanks.
