miroxp |
08-19-2015 01:54 PM |
Removing Evaporator+Expansion Valve on Camry 2008
Hey guys,
I am in urgent need of help on the following. My A/C started to smell bad about 3 months ago after almost 7 years of non stop perfect action. Late June a loss of refrigerant occurred and it stopped blowing cold. The shop re-filled small amount of missing Freon (not even half was gone) and we all assumed that it could be normal after all those years. But it was showing signs of leak a month ago again since the cold started to turn not-so-cold. They injected dye in the system and inspected it two weeks later using UV light and nothing was showing in the engine compartment. Then they tested the inside (removed the cabin filter and stuck the probe inside, car not running) with a Freon leak detector and it started "singing". Now I know where the leak is and it most likely is the evaporator or the expansion valve. Now the tough question - do I have to remove the ENTIRE dashboard and everything behind it in order to get to the evaporator or removing the glove box and the blower underneath will give me access to it. I watched some "horror" videos of removing the entire front and honestly if that's my only option I will rather go without A/C. I couldn't find the answer for this model/year even though there are some videos about '05 but I guess it's not the same. Any ideas, suggestions or schematics would be extremely appreciated. Also, since I will be buying an evaporator+expansion valve, do you have any comments on which brand should I go for? Damn, I thought this car will never give up on me...Thanks a million!
