Removing seat belt
Hey everyone,
new member here, I have got a 2004 camry and the seat belts aren't retracting as smoothly as I'd like. Couldn't find a post about this although I'm sure there is one. Any advice or good videos? Thanks. |
Check the belt for twisting. However typically its the retractor mechanism.
Set links below for suggestions. https://www.diyforums.net/diy-fix-fo...ctor-1350.html https://www.diyforums.net/slow-lazy-...on-116257.html Note that some retractors have a pretension system tied to the airbag system. When the airbag goes off, the pretension system snugs the belt up. If the retractor has such a device, it may complicate things. The best advice is to replace the belt system with a new or refurbished one. There are aftermarket units available. |
Awesome. Thanks for your help
