Replacing Camry Emblems
I have a '97 Camry with gold emblems that have faded and oxidized to the point they are very dull and unattractive. I want to replace them all, and I know about using a hair dryer on the rear (trunk) emblems to loosen the adhesive. But how does the front grille emblem attach? The same as the rear? Some advice would be much appreciated. Thank you!
Never removed one, however.
The link below has photos: Front Grille Emblem Toyota Camry 1997 1998 1999 2000 2001 Genuine Part | eBay Appears to press into hole, may have a built in spring clip to hold it in. Suggest removing the grille for access to the back where the removal method should become obvious. |
