Replacing fenders on 2009 Camry SE.
Hi. I'm getting my fenders replaced and I need to know how to disassemble them off my Camry SE. I've already figured out how to remove the front bumper so where do I go from there? How many screws should I be expecting to take out and will there be anything hidden that I should be aware of? Thanks!
Removing the bumper cover should have exposed several fender fasteners.
Next remove the plastic fender inner wheel well lining. Between the two parts being off all fasteners should be exposed. The internet has photos of new fenders having some fasteners holes shown. If you poke around the other locations should be obvious. There fender/body joints may have had sealant applied after they were bolted together which could continue to hold the fender to the chassis once all fasteners are removed. Take note there is a airbag crash sensor located on each side of the car under the headlight area. Don't go banging around in this area. You might disconnect the battery before doing the work. |
