timing belt
timing belt
hello, newbie here, I was wondering about my timing belt change. I am looking at the factory manual and it says to rotate the crankshaft counterclockwise? then after making sure everything lines up, then you rotate clockwise? I just wanted to make sure I am correct that I need to rotate the engine backwards!!??
lesaroka
09-12-2005 10:58 PM
