Serpentine Belt Replacement
Old Jun 21, 2025 | 07:12 PM
JimsKayak's Avatar
Default Serpentine Belt Replacement
It seems like a fairly straightforward job, but I don't "get" how the tensioner works.
1. Is it really necessary to replace the tensioner?
2. Is the tensioner pre-set, with a spring, or does it need to be tensioned to a torque spec?
3. It seems like the easy way to get at it is by removing the passenger side wheel and the plastic cover in the wheel well, but I see (in videos) people getting at it from the top with what looks like a super-long box wrench.
Every other belt I've replaced (on other cars), there has been some kind of locking bolt, and a range of adjustment. Help me unlock the mysteries of the tensioner!
Old Jun 22, 2025 | 02:29 AM
Year? Engine?
Old Jun 22, 2025 | 05:25 AM
JimsKayak's Avatar
2016 le 2.5l
Old Jun 22, 2025 | 11:20 AM
1) No. Inspect it for damage and check it is free to rotate and still applies tension.
2) Preset.
3) See video.
https://www.google.com/search?client...0wkvYHKTs,st:0
Old Jun 23, 2025 | 11:41 AM
JimsKayak's Avatar
Link for videodoesn't work
Old Jun 23, 2025 | 09:42 PM
Old Jul 2, 2025 | 05:57 AM
JimsKayak's Avatar
Easier than I thought! I could easily reach the tensioner with a wrench from the top. The "bolt" to turn is easy to spot, because it isn't really a bolt, its a bolt head cast in the tensioner. Some tips for anyone reading this
post:
1. Draw a picture of the route the belt takes. By Rule of Thumb the un-grooved back of the belt only touches the tensioner and an idler wheel.
2. Do remove the passenger side wheel and the plastic splash guard/cover- it makes it much easier to access the belt.
Dubi2017
Aug 28, 2018 08:30 AM
technut
Dec 29, 2016 10:25 PM
darkfreelife
Jun 18, 2014 12:38 PM
71-BUG
Oct 24, 2009 04:18 PM
usnavyvetmissouri
Mar 23, 2008 02:55 PM
