Shuttering
Hey my 94 2.2liter(4cyl) Shutters on the 1st startup of the day it doesent matter if its morning afternoon or a cold or hot day. My driveway is pretty steep but i dont think thats the problem if i give it a little gas it stops shuttering its when its idling it does it. It does it for about 5 to 10 minutes after that it runs fine. Anyhelp would be great thanks.
Try it on a level surface, see if it helps, if so the pickup in tank may be loose.
If no help, you would start by checking fuel pressure with a mechanical gauge. Do you have a DTC light on? |
