The T-stat has an o-ring (called a gasket) that goes around its outer flange.
Is the Stant 17538 the right part number? Both Gates and Dayco are good hoses. Use a coolant labeled for Asian cars. |
Thanks.
I meant Stant Thermostat #13758. Thanks for pointing that out. I corrected my original post accordingly, and here's a a link to that thermostat: |
The 13758 T-stat should be fine.
thanks
Thank you.
