Throttle Body Cleaning
I car is facing rough idling. So, I want to clean the throttle body. On the internet, I have found that I can use WD-40 to clean the throttle body.
Is it harmful to the engine, if I use WD-40? I found the information here 6 Common Dirty Throttle Body Symptoms - Auto Parts Guideline Looking for an experts opinion. TIA. |
Use something labeled throttle body cleaner. Open throttle plate to also spray behind area.
Let soak. Use a toothbrush to scrub the area. Clean up with cloth, etc. Search under "cleaning throttle body Camry" |
