timing belt
hello, newbie here, I was wondering about my timing belt change. I am looking at the factory manual and it says to rotate the crankshaft counterclockwise? then after making sure everything lines up, then you rotate clockwise? I just wanted to make sure I am correct that I need to rotate the engine backwards!!??
Always rotate CW. The belt is under proper tension when rotating CW.
that is what I thought. I will make sure I am looking at the correct thing. thank you.
