Toyota Camry 2010 Replace Front Bumper Grille - Front, Lower
Hi,
I am new to his forum,and am trying to get some help in replacing the front bumper grille (lower) on my newly bought (used) toyota camry 2010. I just realized that the Lower front Bumper Grille (plastic one from the factory) is displaced and was hanging in the bumper cover area. I really appreciate any help in snapping it back in, or, is it a bigger job than that, and visit a repair man? Please help this novoice. Thanks in advance. |
The lower radiator grill? If so it is held in place by a great number of built in claws around the circumference. Unless broken you should be able to gently move it back into position.
Perhaps you can make something to reach through the grill and pull it back into position. Pull only on the outside of the grill. If the grill is broken the bumper cover may need to be removed to access the part from behind. This is not a hard job, a number of bolt around the circumference of the bumper. |
Toyomoho,
Thank you very much for your quick and accurate reply. I was able to snap it right in. You spared me a visit to a mechanic!! Thanks a lot! |
Great, glad to help.
