VSC & ABS Flashing
My 2002 Toyota Camry XLE 3.0 is all of a sudden flashing VSC & ABS on the dashboard. This was after I noticed the check engine light - it was a bad O2 sensor. Anyone ever get the VSC & ABS flashing too?:(
Mine did that too after scanning for codes. Now my VSC and Trac light are always on. Read code for that it says it has to go to dealer to do some sofiscated test. Same vehicle.
Some code readers will cause this problem.
The issue may be the need to reset the zero point calibration. |
EXACTLY, the code reader caused this problem and it does need to be reset. Do you know how to zero point calibrate it???
Reset the zero point calibration
How do I reset the zero point calibration on my 2002 Camry?
