What is this sensor? '95 Camry
https://www.flickr.com/photos/138454...n/photostream/
Working on rebuilding an engine after a fire. I can't find any information on this sensor that's right on the front of the engine. I thought it was a crankcase position sensor, but it looks like that one is somewhere else. Any ideas? Engine is 5S-FE 1995 Camry 4 cyl. Thanks! |
I waited quite a while .. i could not get the image to open
without a picture which way are you facing you are rewireing from an engine bay fire ...wow...... what a job did you get a new loom or second hand loom from a wrecker to save time if the area got that hot check the timing belt |
Weird. It's on flickr here:
https://www.flickr.com/photos/138454...n/photostream/ hope that works. Thanks for the idea! Yeah I got both O2 sensors on the exhaust, but this sensor is on the engine itself. Far right side next to the coolant outlet. just under the valve cover. It's wires were kind of bundled with the O2 sensor wires, both heading toward the ECU (I believe). As for the loom, yeah it's a mess. but fortunately (somewhat) the fire retardant wire covers did a pretty good job. I was able to trace each wire from one side of the loom to the other. I cut out the middle bit where the damage was and will add new wire with connectors and solder. Speaking of that , these connectors are hard to find too. Anyone know where to get the right connectors without having to buy 1000 at a time? |
1 Attachment(s)
i see the image now
does this attachment help |
1 Attachment(s)
the image of the engine in html
connectors = yes ask at any local auto electrician shop |
Yeah that diagram makes it look like the knock sensor, but according to my Haynes manual, the knock sensor is V6 only. Also it places it INSIDE the intake manifold.
Alldatadiy has the same diagram you provided. I think you may be right though. Thanks! |
2 Attachment(s)
a 1995 4 cyl has a knock sensor
in a 1990 4 cyl camry repair manual (gregories)same spot says and oil pressure sender if you can't tell after yours has been in a fire to really know ....undo that sensor... and go to part identification oil pressure sender has a tapered thread.......... a knock a straight cut thread |
Confirmed,
It is an Oil pressure Sender/switch Thanks for the help! |
