1991 All Trac dash 4WD indicator light not working
Old 12-27-2008, 11:23 PM
baboonia's Avatar
Default 1991 All Trac dash 4WD indicator light not working
I have a 91 All Trac, 4 cyl, automatic.
The 4WD system seems to be working fine, but the indicator lamp on the dash above the glovebox never comes on. Could it be a burnt out bulb? (I've owned the car about 1 year and the lamp has never worked)
Does anyone know what kind of bulb is used and how to get access to it? Hopefully I just have to remove the glovebox...
Old 12-29-2008, 08:42 AM
Default RE: 1991 All Trac dash 4WD indicator light not working
If the bulb the instrument cluster needs to be removed. This is pretty straight forward if you know what you are doing.
Try the autozone website at www.autozone.com for info on removing the cluster.
http://www.autozone.com/shopping/rep...00c152801ccd9b
Have not idea of bulb is used but a Toyota dealer may be able to help.
jfirusta
10-05-2011 04:41 PM
PAUMA
03-06-2010 11:08 AM
Mikeallenmikeallen
09-28-2009 08:41 PM
2005 Camry
01-22-2009 09:15 PM
jonathaninwa
04-04-2007 05:54 AM
Quick Reply: 1991 All Trac dash 4WD indicator light not working
