1995 2.2 OBD code 14
Old 02-24-2017, 08:04 PM
StephiesMan's Avatar
Default 1995 2.2 OBD code 14
I have a 1995 2.2 I4 LE and it doesn't wanna start. It will turn over for a while, and after a few tries (Turning the key to off, then trying it again), finally start, and when it starts it'll idle rough and feel like it wants to die, and will make a "POP" when it's starting, but then it warms up and runs fine. Got a CEL and the OBD I said code 14, something to do with the ignition. Please help? Let me know if you need anymore information.
Old 02-24-2017, 10:08 PM
dirty hands's Avatar
could be the coil or its exciter
try this
undo battery terminals and clear code.. see if the code returns
toyota with code 14 random information off the internet
Code 14: IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
IGF (I Got Fire) is the ignition comfirmation signal from the igniter to the ECM
If the IGF signal is lost for 6 ignition firing events (3 revolutions)The ECM shuts off the injectors.
Old 02-25-2017, 07:52 PM
I tried undoing the battery posts for a while and it still acted the same.
Changed the whole distributor and it starts better than it ever had before.
thank you for the suggestions
Old 06-23-2018, 07:33 PM
1995danle's Avatar
What brand of distributor did you use?
traviskx
08-21-2019 08:45 PM
seasam
03-10-2016 10:47 PM
BigTone258
08-09-2015 11:58 AM
micamry93v6
01-17-2009 10:55 PM
X53Gunner
03-17-2008 06:17 PM
Quick Reply: 1995 2.2 OBD code 14
