Browse all: Electrical Guides
- Toyota Camry: What's Wrong with the Master Switch?
Guide to diagnose trouble and recommended solutions.
1997 Camry power window master sw
The power window master switch will not work. The switches on the other windows work fine. I've noticed the when I take out the 25 amp fuse then put it back in it works. One time only. Since the other windows work I would think the 30amp and the power relay are working. In the Hayes manual the diagram shows that the power splits to go to the master switch and the other switches. Are the connections under the dash board? What is an IE2 before it goes into the junction connector?
1ATony
01-11-2011 08:35 AM
J2Performance
12-13-2007 11:46 AM
J2Performance
12-13-2007 11:25 AM
J2Performance
12-12-2007 06:10 PM
