1999 camry xle remote door lock malfunction
HI
Anyone able to help with my remote malfunction. I bought two new remotes from amazon. I went through both procedures described in previous threads. The one using the key. The other shorting pin 2 and 10. Results: No cycling action at all using the key. Tried about 5 or 6 times. shorting pin 2 and 10 on remote mirror switch socket. It only locked the doors. It did not cycle them as instructions indicated. Where do I go from here? Thank you, Schnamry |
Does the car have an anti-theft system?
Post thread to Amazon remotes. |
Antitheft system.
Yes it went off the other day and i had trouble shutting it off if this helps.
Is this an aftermarket alarm, Toyota factory alarm or?
Links to Amazon remote purchased. |
Thankyou for your support. Too busy to follow up at this point.
Don |
