2000 Camry Dash Board lights
I havea few lights out on the dash. The first is thefan speed control and hot/cold temp on a 2000Camry.If anyonehas taken the dash apart on this year is itdifficult andare there any tricksI need to be aware of?
Thanks, Joe |
RE: 2000 Camry Dash Board lights
No, it's not too tough. I have a 98 Camry and I've done it plenty of times before, and I assume that it should be the same thing as a 00. All you got to do is unscrew the screws on the housing pull it out, then there might be a few more screws to unscrew from the odometer itself. Once you pull out the meter, just turn it to the back and you will see 5 LED's (that's how many my car has, should be the same for yours, too). All you do is take out the LED's that aren't working and put in the new ones. Here is a website you can visit to buy LED's: www.superbrightleds.com
