2000 camry le
Old Nov 30, 2021 | 06:48 PM
firedozerrich's Avatar
Default 2000 camry le
2000 camry is daughter in laws car, problem started a couple of months ago, with ign switch locked and key out, oil press icon is lit , power sits and windows, as well as heater/ ac fan are powered up and working, the remote entry fob is not working as well as the headlights on after the car is stoped and key removed , my thought is a fried closed acc relay ? anyone have any thoughts?
Old Dec 1, 2021 | 01:13 PM
Speculate an ign switch has issues. The ign "switch" is really two switches ganged together. The switches are attached to the back of the ign key unit.
The electrical system is designed to route some 12v power through the ign switches and some directly from the battery.
The oil pressure light gets power from the Gauge fuse which is routed through an ign switch.
The power window system (motors) gets power from the Power Relay which eventually comes directly from the battery. Something called an integration relay (solid state design) controls the power relay on/off. The integration relay receives from several sources one being the Gauge fuse. The reason the power windows still work for a time when the ign switch is off is because of the integration relay which has a timer to leave the windows powered for a time.
If the oil pressure light is on and power windows never shut off would look at the ign switches.
Youtube may have videos on replacing the ign switch.
Stephenapp
Jan 12, 2023 08:04 AM
1989_Camry
Dec 28, 2021 01:53 PM
camryazn136
Apr 15, 2012 10:28 AM
blaggon
Sep 10, 2011 11:00 PM
nocitychick
May 8, 2011 12:33 PM
