2001 Toyota Camry - Changed Battery, Low Idle, Engine Shaking
Hello, My 2001 Toyota Camry had its battery changed about a week ago and the first time driving it after I did that, the car has been barely idling. It hasn’t stalled yet but once up to temperature, it idles anywhere from 100-300rpm at most. The exhaust and catalytic converter were fixed. I have installed new spark plugs. I have NOT cleaned the IAC valve yet. I have tried two different idle relearn procedures online. Has anyone experienced this problem with this 2001 Model Year? |
For this type of problem, you will need a scanner and someone who knows how to read it. Not just look for codes. Hope you know someone who can help you.
Sam F |
Disconnecting and reconnecting the battery can cause idle issues for a time. Most likely the situation will straighten itself out over time. Try this first before doing any repairs.
