nycmaster |
01-13-2021 11:24 AM |
2005 Camry LE 4CL Multiple Re-learn!!!
Desperately seeking answer (now you know I'm a child of 80's!!) - Needed to replace alternator and battery. Replaced them at same time and went through idle re-learn process.
- After first re-learn, idle rpm went up to 680 - 700. Turned ignition off and restarted 3 times and car and idled smoothly. Did NOT drive around for few miles since they started fine and smooth
- Next day, car started fine and smooth, went grocery shopping (2 miles from my house). Shopped about 50 min, came back to start my car, BAD idling 450-350 RPM and shuts off.
- Drove as is engine shutting off on every red light (About 5 of them). I was able to restart the car every time on Green light and got my self home.
- Disconnect the negative of the battery, waited about 5 MIN and reconnect. Did the Second Idle re-learn and successful. Idle RPM stable at 680-700.
- After second re-learn, took the car and drove highway about 30 miles and returned home. Started my car from driveway about 4 times after 30 miles of highway, Camry started fine and smooth idling
- This morning which is about 48 hours since #6, bad idling. 450-300 RPM and shuts off.
- Multimeter shows battery at 12.6V with engine off and hovers around 13.6V when idling
- Just did third re-learn and idles at smooth 680-700
Any suggestions on what to look for? Could the problem be somewhere else?
