2010 Base Camry - SRS and TC lights on - Fuse 29 Blown
2010 Base Camry - SRS and TC lights on - Fuse 29 Blown. Passenger doors do not open with remote. I replaced the fuse 29 and it blows when the ignition is turned on. I also noted that the dome light is off. Noted that Fuse 30 is missing. I believe it should it be installed on a base 2.5L 4 cyclinder engine. Appreciate the help to diagnose the issue. Thank you.
