2012 Camry SE Passenger Side DRL and high beam not working
Hello, I own a 2012 Camry SE, and recently my passenger side DRL and high beam are not working. I've changed the bulb thinking it was the issue to no avail. I've checked the plug and Im not getting any power to it. I know there is no direct fuse for the high beams like most cars, which is leaving me clueless on what the issue could be. Also having no luck with Google or any other site. Any idea what the issue could be? Driver side DRL and high beam works perfectly fine as well as my low beam lights working fine. Just no power to passenger side drl/highbeam.
Also passenger side high does a single quick flicker when you active the highbeam but doesn't come on. |
Suggest you access a wiring diagram. For $20 one can get 2 day access at
https://techinfo.toyota.com/techInfo...arch_docs_page In past designs there was one fuse for each head light filament as in low R/L and High R/L thus 4 fuses. Check the owners manual for fuse locations if they exist. Here both sides High and DRL +12V were tied together prior to the DRL relay. As such if one side High/DRL worked the other should be powered also. If not a wiring issue or fuse issues. |
